Poor man's locator
  • Poor man's locator
    Anyone have the info for this homemade locater ? 512 signal generator , amprobe with coil. I know it wouldn't give depth, and would be limited. I don't need much! Thanks Tool
    Re: Poor man's locator
    Just use a measuring tape and paint on ft and inches
      I have a probe this clay is hard as a hoar"s Heart
        I don't see a pic or link
          tool, i have plenty of locators and i'm sure even a poor man can afford 1. but 512hz. would still require a transmitter and i have some sondes you can tape onto the snake or install on your general with a leader.
          you have my #
            Tool, I got one of these thats for sale...make me an offer
            Progressive Electronics Model 501 Tracker II Underground Cable Locator System
            Model 501 Tracker II offers professional performance in wire locating. With its inductive signal application, the Tracker II can be used on active or dead systems. Now you can trace the path and determine the depth of wires and metallic pipes without having to deactivate the systems. The high frequency transmitter provides range up to 4000 feet and depth to 7 feet. The transmitter offers three methods of connection: direct, inductive coupler or inductive antenna. The 32 inch light-weight receiver provides both audible and visual indications of signal strength for accurate identification. Transmitter output and receiver sensitivity are both fully adjustable for maximum accuracy.
            The Model 501 Tracker II includes: transmitter assembly, receiver assembly, inductive coupler (clamp), inductive antenna (built-in), two 8 foot test leads with heavy duty alligator clops and a durable polyethylene case.
            * Locate to 7' depth, 4000' length
            * CATV, telephone, water, gas and electrical
            Powerful RF transmitter attaches directly to shielded or unshielded wire, metal conduit, water or gas pipes. 33" T-handled pick-up has visual and audible indication for direction finding and determination of depth. 3" jaw clamp induces tracking signal onto line when direct hookup is not practical. If line is completely buried, an inductive antenna is built into the carrying case that will induce a tracking signal onto a line up to 7' deep.
            Technical Specifications:
            Power requirements:
            Transmitter - eight "AA" batteries / Receiver - one 9V battery
            Battery Life: Transmitter 30 hours / Receiver 10 hours nominal
            Transmitter Frequency: 447.5KHz Transmitter
            Power: 40Vp-p (140mW) maximum
            Voltage Protection: 240VAC, 500DC
            Construction: Transmitter/Receiver - powder coated aluminum / Case - vacuum formed polyethylene
            Dimensions: Transmitter - 4.25 x 3 x 3.25" / Case - 33.5 x 8.25 x 3.75"
            Weight: 6.7 pounds (complete kit)
            Included Accessories:
            * Model # 501T Transmitter
            * Model # 501R Reciever
            * Model # 500CA Carrying Case With Inductive Antenna
            * Model # CS6 Cord Set
            * Model # IC-I Inductive Coupler
              you have my #
              Can't find #
                how about my email
                  Here's Ricks Number xxx-xxx-xxxx
                  Seattle Drain Service
                    There is a homemade way to do it with a coil and..... ah he!! I can't remember.
                    Better off giving All Clear a call if you want a good deal & medium accuracy.
                      how about my email
                      Sent one Box is full !
                        email, not p.m
                        i'll email you
