Just want to make sure of something....
  • Just want to make sure of something....
    I'm assuming that the Navitrack II will locate any sonde transmitting at 512hz, even if it's from a different manufacturer. Am I correct in this assumption? Just want to be sure
    Ideal Plumbing
    Re: Just want to make sure of something....
    You are correct.
      512 is a very common sonde for cameras to penetrate cast iron.
      but it's not limited to just 512hz. it will do
      Standard Frequencies
      Sonde:512 Hz.Active Line Trace:128 Hz, 1 kHZ, 8 kHz, 33 kHz, 262 kHz.Passive AC Line Trace60 Hz, 50 Hz.
      Additional Frequencies
      Sonde:16 Hz, 640 Hz, 850 Hz, 8 kHz, 16 kHz, 33 kHz.Active Line Trace:65 kHz, 200 kHz.
      http://www.ridgid.com/Tools/NaviTrack/index.htm
        Thanks That's everything I needed to know.
        Ideal Plumbing
