seesnake sonde
  • seesnake sonde
    just purchased a used color camera 200 mini and locator can not find it
    do i take it apart like everything else or is there a reset?
    does the sonde go bad?
    and my last question is it an easy fix?
    Re: seesnake sonde
    Are you sure it has a sonde?
      Re: seesnake sonde
      depending on the age of the camera, the early models did not come with a sonde, but that's been a good 10 years back or so.
      there are 2 models of sondes for the mini. the original black pill style was always live if i remember correctly and the newer clear capsule is only live when you energize the sonde.
      the sonde is located approx 4'' behind the camera in the spring.
      if you see fuzzy lines in your video monitor, then the sonde is powered on.
      if you need a replacement, i have a brand new sonde for the mini on the shelf
        Re: seesnake sonde
        You can see if you have a transmitter by bending the spring a little bit and looking behind the head.
        The new ones are maybe 1/4" long with and antenna at both ends and a wire should be wrapped around both antennas.
        The older transmitters where larger and did not have the exposed antennas.
        Rick is right about being able to check if your transmitter.
        Try and turn it on, if your monitor gets lines running thru it, the transmitter is energized.
        If you have any questions give us a call, we are a Ridgid Repair Center.
        http://www.tradetoolsupply.com/repair.html
