Locating
  • Locating
    I have the navi trac scout that I use for my sewer camera. But lately I have had a few jobs where I needed to loacate a water line. Is there some sort of toner I could hook to a fish tape and run it up a water line to locate it. Nothing fancy just something inexspensive and reliable.
    Thanks
    Mike
    www.plumbinginclarkcounty.com
    Re: Locating
    You can put a transmitter on the fish tape. Or if the actual line is metallic, on it. I'm not sure how a fish tape would work "returning to ground". In short, giving a readable signal to the receiver (NaviTrack).
    Ridgid/Seektech make transmitters. Other companies as well. The frequency must match each other.
    Example: If your scout can receive a 10Mhz signal, the transmitter should have a setting for 10Mhz also. Make sense?
      Re: Locating
      So will the brick work with scout
      Mike
        Re: Locating
        Yes but if it's a metalic pipe you do not need a fish tape.
          Re: Locating
          I located a 1" pvc water line about 75' long with a fish tape and my cable hound. It's a locater I use to hunt down irrigation valves. Fortunately it was a straight run. I don't know the efficacy of fish tape if there were turns. And as J.C. noted the ground is an issue. I got a really good tone on that one but others haven't been so good.
          Thanks
            Re: Locating
            I traced an empty 1.25 PVC line that was buried in the same ditch as one of the distribution lines in Utah. I was limited to 325' because that was the longest fish tape I could fine. I refused to have the water company adopt the line to the subdivision because they did not run a tracer line.
