micro drain sond
  • micro drain sond
    my micro drain w/explorer has no sond . is there an easy fix?
    Re: micro drain sond
    Tape a bullet Sonde to it or you will need to buy the model with the sonde built in..
    I can't see an easy fix
      bummer !
        unlike the larger see snake camera systems. the micro drain and micro reel have the sonde incorporated into the camera head itself. so basically a new camera head would be required. a tape on transmitter would work or if you have a newer monitor, you could connect to a navitrack transmitter and energize the push rod of the camera. of course a sonde is dead on accurate for locations.
