When the lights went out
  • When the lights went out
    My system was damaged yesterday when the camera head contacted the cast iron stack. A spark jumped to the head and toasted my whole system. Has anyone else seen anything like this? Now I am paranoid as hell about using my other systems how can or could I prevent this? Lots of $$$$$$$ I am sure in repair
    Re: When the lights went out
    sounds like the cast iron stack is energized
    i think your camera might have just blown a fuse in the countr plus
    might be a simple fix that a repair center can get you up and running
    i would suggest to have the property owner get a qualified electrician to check out their electrical system
    rick
      Had the same thing happen to a 5/8" cable when I was snaking a floor drain with my k50..Turned out there was a short on the switch .Sparks were arching across the cast iron floor drain.Scared the hell outta me
        Crazy stuff!
        I never ran across anything like that before.
          You had a charge in the line it usually will take out the camera head, transmiter, counter and the power supply in the monitor. If you have a monitor that is on batterys you will not have that happen. Marvin
            Marvin the power supply seems to be ok as I can still watch stored video. But everything else is toast I havent gotten it to a service center yet to know how bad it is. Other than using a battery power unit ( This unit was not ) what are my options for protecting my investment in the future. If you or anyone eles have any sugestions to help I am sure a lot of people will be interested. Thanks again and I will be having the electric system tested on the house
              You should be able to test a cast iron pipe for an electrical charge with a multi-meter I would think. If that sewer pipe was energized and damaged your equipment, I would think that insurance of the property owner should cover the damaged equipment?
