512 mhz transmitter? Page Title Module
  • 512 mhz transmitter?
    Can I use my Scout to locate water lines, gas lines, etc if I use some sort of 512 mhz transmitter?
    Thx, David
    Re: 512 mhz transmitter?
    Yes...
    Derek
      Cool, any transmitter suggestions?
      David
        David
        Ridgid Navitrack Transmitter / Brick
          ^^^^yep....what he said^^^^
          Derek
            Perfect, thx.
            David
              I use the larger 10 watt.
              What is the brick, 5 ?
                here's the owners manual.
                http://www.ridgid.com/ASSETS/60D82DC...mitter_Man.pdf
                locating pipes and utilities you start off with lower frequencies. they travel further and bleed over less.
                512 is a frequency used for locating the camera/ sonde.
                  I have the Scout. I believe it is 512 mhz only.
                  David
                    David
                    Scout sonde, 512 Hz, 640 Hz, 874 Hz and 33 kHz
                    Scout line trace, 50 Hz (Passive), 60 Hz (Passive), 512 Hz, 8 kHz and 33 kHz
                    http://www.ridgid.com/ASSETS/24D5A30...ocator_Man.pdf
                      I bought the ST-510.
                      SeekTech ST-510 Transmitter - RIDGID Professional Tools
                      We will see how it earns it's keep.
                      David
