Infrared Camera
  • Infrared Camera
    Is there anyone out there that has one besides me? Do you charge extra for it? So far it is helping me with everything but wonder if I need to be charging for it.
    AllurePlumbing.com
    • leak detection
    • drain cleaning
    • utility locating
    • conductor fault locating
    • and other specialties.
    Re: Infrared Camera
    The old black and white compacts had infrared heads they had a black pushrod there are some left but if they kink we or ridge will not returm them anymore marvin
      Re: Infrared Camera
      something tells me that he was referring to a handheld i/r camera that he uses to locate heat loss.
        Re: Infrared Camera
        What a great tool. For what purpose did You by it? Yes, in My opinion ,You should charge for it.
          Re: Infrared Camera
          I use it to compliment my leak detection for the most part. It helps track down recirc loops in commercial amps. Then I can determine hot/cold from the ground. Overkill for line tracing but it helps. I use it for comparing pumps in commercial. Nice to find manifolds in the walls....unless in a tub wall. Heat doesn't build up well for detection without cutting the wall open.
          AllurePlumbing.com
          • leak detection
          • drain cleaning
          • utility locating
            Re: Infrared Camera
            i have one its the little milwaukee 12 volt guy... i use it in the same application as you do just to compliment my leak cetection... although i have used it on some repair work on a vent stack...works really well for recircs as you said.
              Re: Infrared Camera
              Can you take a picture to share with your customers?
              AllurePlumbing.com
              • leak detection
              • drain cleaning
              • utility locating
                Re: Infrared Camera WOW RENT A FLIR 17 AT HOME DEPOT
                All over the boston area !!!!!!
                  That is friggin awesome. I didn't realize the rented equipment like that at a hardware store. It would be a pain for me to run there every time I wanted/needed it.
                  AllurePlumbing.com
                  • leak detection
                  • drain cleaning
                  • utility locating
                    Re: Infrared Camera
                    Thanks for this thread! Do You realize the trouble You've started? Now Rick will be Buying at least 3 of these cameras! How do I know? He didn't jump in with pictures of His already ! Sorry Joey.
                      Re: Infrared Camera
                      The prices have become reasonable. I like mine. There is still a lot I need to learn and a lot of free classes you can take on Flirs website. I would recommend this brand due to cost by comparison that I had done.
                      AllurePlumbing.com
                      • leak detection
                      • drain cleaning
                      • utility locating
                        Re: Infrared Camera
                        I just bought one for $25.99 on Amazon ! Well kinda did. black+ Decker Thermal Leak Detector
                        Good to show Mrs. Murphy and Her Kids the heat loss when they leave their front door open !
                        Is a $2.00 tool charge too Hi ?
                          Re: Infrared Camera
                          Playing with my camera.
                          AllurePlumbing.com
                          • leak detection
                          • drain cleaning
                          • utility locating
                            Re: Infrared Camera
                            AllurePlumbing.com
                            • leak detection
                            • drain cleaning
                            • utility locating
                              Re: Infrared Camera
                              My friend has the large Ridgid SeeSnake, black & white with the gray pushrod. Are these still retermable ?
