Leak sound detection equept. Around $400.00
  • Leak sound detection equept. Around $400.00
    Any suggestions for listening devices for finding Water leaks under slabs ? Was looking at Amprobe ultrasonic leak detector around $400.00
    Re: Leak sound detection equept. Around $400.00
    kevin, there's a whole lot more to leak detection than just a listening devise.
    you also need a pipe locator to home in on the location of the piping.
    plus leak detection is not something you learn overnight. it's an art that takes hands on training and years of hit and miss
    compressed air and a good stethoscope will work for not so deep locates. plus much cheaper and no filtering frequencies.
    can you hear me now
      Leak Pro
      This is what I use. Just saying.
        I use a one of the best if not the best equipment and as Rick said, it is not the only equipment needed and it gets costly. The learning curve is pretty steep no matter what you have or who is teaching you.
        AllurePlumbing.com
        • leak detection
        • drain cleaning
        • utility locating
        • conductor fault locating
        • and other specialties.
