Ridgid 95542 compact plus
  • Ridgid 95542 compact plus
    I just purchased this unit, and I am confused on how the image flip feature works.
    I know I don't need it but would like to be able too if I wanted to do so.
    Any info would be greatly appreciated.
    Connor
    Re: Ridgid 95542 compact plus
    Pressing the image flip key will rotate the on-screen image 180 degrees. This is useful when the camera is upside down in the line (helps you maintain your sense of direction as you're pushing through the pipe).
    NOTE: This affects what's displayed on the SeeSnake monitor screen ONLY - if you are recording the image it will not appear when you play back the recording.
      i have the monitor with just the one button that toggles all the features, i just cant seem to flip the image.
      thanks
        It looks like you have an older unit with a single multi-function button and either a color or B&W monitor. Both monitors have controls for image adjustment; the button on the far right rotates the image.
