Dvdpak not recording audio
  • Dvdpak not recording audio
    As it says, my dvdpak won't record any audio.
    Anything silly I can check before I send it off?
    Thanks,
    Todd
    Re: Dvdpak not recording audio
    double check you didn't hit the mute button. there is a screen icon with a red slash through the microphone if it's muted.
      I've burnt a couple tests pushing the mute button multiple times-mute on, mute off, and back and forth. No difference.
        The microphone is not a part of the sony burner. It's a separate component and plugs in most likely through a rca jack powered by a pre amp. Not sure other than checking the connection if it's user serviceable.
        Rick.
