camera jetter
  • camera jetter
    Did a camera inspection from an outside cleanout going under the house. About 6-7 feet under the house found thick sewage. Some one ran their cable through and nothing changed. They had a drum machine.
    Roots beware of the C snake with shark teeth.
    Re: camera jetter
    Soft Stoppage 101 lol. Now you are going to hit it with a jetter? Or struggle with a sectional?
    Seattle Drain Service
      Re: camera jetter
Name:	morton, 217 e. Kay 2of3.jpg
ID:	627684I will try to make the picture bigger so you can see it in action. You can see the end of it on the top left side and the water coming out.
        Re: camera jetter
        I just found out that if you click on the picture it will enlarge. Nice. Here is a picture of the jetter set up.
          Re: camera jetter
          The soft blockage is about 15-20 feet long. This would not be hard with a sectional cable(c-14).
            Re: camera jetter
            My father used to do this with the old flat tape hand rods. Tape a garden hose to the rod and push it into the plugged sewer. When the water stopped backing up but the sewer still was plugged meant the hose end past the blockage, he pull back till it started to back up again and just work that spot till the line opened.
              Re: camera jetter
              there are a handful here that use a forward rotor jetter nozzle with our camera taped to the hose.
              I've cleared lots of sludge lines with a good garden hose and nozzle. but you're limited to the size of pipe, stiffness of the hose and type of bends. 2'' pipe with 45's are the best.
                Re: camera jetter
                This was not very hard. Down the cleanout and straight to the back of the house. Only 35 feet in 4" clay pipe. The hardest part was the joints had settled.
                Here is a picture where a wet wipe got packed in between the pipe joint.
                  Re: camera jetter
                  Pipe patch that mofo!
                    Re: camera jetter
                    The sewer pipes have settled under the basement floor. It looks like a bunch of speed bumps. Every joint is bad, some worse than others. I think they are going to break up the floor and replace it all.
