SeeSnake Questions
  • SeeSnake Questions
    I just got a SeeSnake Mini last month. I also got the CS10 monitor. I'm wondering about the storage of this stuff. HOw well can it take the heat and cold?
    Will Rogers Plumbing
    Moore, Oklahoma
    405) 323-2852
    www.willrogersplumbing.com
    Re: SeeSnake Questions
    I don't know about the heat cold question, especially cold. But I have a tip I've used for the last ten years.
    Store all these seesnake items on a foam padding of some sort in your truck. Especially a monitor. This to lessen the vibrations and subsequent failures that can result over time if they aren't.
      My manual said the CS10 storage range is 14F to 158F and the operating temp is 32F to 104F.
      And for the seesnake mini the storage range is -4F to 158F and the operating temp is 32F to 104F.
      Roots beware of the C snake with shark teeth.
        So the garage should be fine then. I don't want to leave it on the van, but I'm sure the wife aint going to let it in the house...
        Moore, Oklahoma
        405) 323-2852
          every seesnbake that is new stays in my bedroom.
          Seattle Drain Service
            It's no longer new after the first time it's stuffed down a dirty azz sewer
              wasn't there a video made by mark that was a spoof of me sleeping with my k-60.
                If there was, this drum guy didn't see it.
                  old time forum members have lots of videos posted on the forum. If only the search feature would work.
                  Mark, can you dig up that video of yours.
                  Rick.
                  Been years since I watched it, but I had a good laugh this morning.
                  Thanks mark.
                  Make sure you take note of all the suttle hints and subliminal suggestions.
                  https://www.youtube.com/watch?v=SVa1...e_gdata_player
                  Rick.
