Nuvi trac brick transmitter
  • Nuvi trac brick transmitter
    Will this transmitter work with other brands of locators such as general spartan gator etc.?
    Thanks for the help.
    Re: Nuvi trac brick transmitter
    As long as it gives off the signal that the locator can find such as 8 or 33.
      Other locators seem to only pick up 60/65. I guess I'm just confused.
        Here are the manuals for general and spartan.
        http://www.psndealer.com/dealersite/...structions.pdf
        http://www.spartantool.com/filebin/p...cator-415R.pdf
        I'm new to using the transmitters, thanks for the reply.
          Yeah doesn't look like it would work. I have a scout which is ridgid's bottom line locator and does location so easy with a brick on copper pipe that I thought it was broken. Maybe you should look into a locator/transmitter combo?
            Bummer for me since I just got a great deal on both of the ridgid transmitters.
            Guess I should have asked sooner
              just get a Scout they are pretty cheap nowdays new and used. If you have a little more to spend get a seektech sr20
              Seattle Drain Service
                Not much cheaper used than new but yeah get a Scout
