Larger pipe diamiter
  • Larger pipe diamiter
    Hi, I do checks on metal pipes from 2 inch to 40 inch. Is there a wheel assembly to accomodate these larger diameters.
    Thanks Chris.
    THEY CAN BE MADE, OR PURCHASED. THE ISSUE IS THAT THE FIELD OF VIEW ON THE LENS IS NOT GOING TO GIVE YOU MUCH MORE THAN POSSIBLY 12'' ON THE FULL SIZE SEESNAKE. ALSO THE PUSH ROD WILL BE TOO FLIMSEY. YOU WILL ALSO NEED MORE LIGHTING TOO. AND YOU'LL HAVE TO USE A PULL IN ROPE. NOT A PUSH ROD. GET A MOTORIZED CAMERA AND CONTROLLER TO DO THIS WORK.
