Monitor will not adjust...
  • Monitor will not adjust...
    I cannot get the picture to stabilize on the monitor. Any suggestions?
    I this B&W or Color?
    When you say "stabilize" do you mean that the video is scrolling vertically on the monitor? If so, then the camera could be the wrong format (CCIR instead of EIA).
    However, this is unlikely, especially if the camera has been in use for a while and the problem just popped-up. You can try adjusting the vertical hold to correct the problem (B&W only).
    Regards,
    TCY
      It is B&W. And yes the problem just started. I tried adjusting the vertical hold but it did not help.
      Thanks
      EJ
