seesnake
  • seesnake
    Has anyone used the seesnake for looking inside walls to find leaking water lines? And if so, does it work well enough to make it worth it?
    I OWN 6 SEESNAKES. CAN ONLY THINK OF 1 TIME I USED IT TO LOOK INTO A WALL. AND THAT WAS TO LOCATE A BURIED CLEAN OUT.
    THE HOLE YOU WILL HAVE TO DRILL IS LARGE ENOUGH TO LOOK IN WITH YOUR OWN EYES. IT WOULD BE DIFFICULT TO DIRECT THE CAMERA TO WHERE IT'S NEEDED. IT USES A WIDE ANGLE LENS.
    I WOULD SUGGEST A BOROSCOPE. IT REQUIRES A 1/2'' HOLE AND IS QUITE FLEXIBLE. COST APPROX. 300. FOR A 2' LONG MODEL. I BELIEVE THEY COME UP TO 6' LONG.
