Dim lighting?
  • Dim lighting?
    Not sure if this was answered before but is there a way to clean up the plastic around the leds? I?ve been noticing on my last couple of inspections that its getting harder to see in clay pipe. Any kind of chemical or buffing solution to clean up the plastic? When you look at the front of the head ,they look dim but when u look at them from the side ,they?re bright as can be
