CS-10 monitor. Need help with flash drive/USB
  • CS-10 monitor. Need help with flash drive/USB
    I just bought a used RM 165 with a CS-10 monitor.
    This is the first monitor that I have ever owned that can record straight to flash drive or USB. I?m looking at buying 100 of them or so so that I can get a bulk deal. My inspections start at the municipal this is the first monitor that I have ever owned that can record straight to flash drive or USB. I?m looking at buying 100 of them or so so that I can get a bulk deal. My inspections start at the municipal tee And I will normally pull back from there to the clean out. Usually takes about two minutes or less. Can anybody recommend how much memory I should have on these flash drives or USBs?
    thank you
    i doubt they still have 2gb but that is plenty if you plan on using 1 per 2 minute inspection.
    Rick
      500mb would be far more than enough.
