B/W to color
  • B/W to color
    I have an old b/w seesnake can I convert to color by just swapping the camera? Do
    they use the same pushrod? It is an old black pushrod 200' never been retermed
    You need a color camera and a color monitor if you have a standard see snake with a number 10 camera head you can get a new color head for about 1000.00. If it is a number 1 or 3 you do not get the deal if it is a mini number 2 also no deal.
      Thanks rod man, just talked to ridge tool they said according to the serial number and color of the reel it was probably made in 1997 and has a #1 camera. The replacement camera #14078 retails around $2500. ser. #011154
        IF it was from 1997 it is not a number 1 the 1 was larger then the spring the number 3 had 4 rings on the head looking like the spring.IT It is a number 10 it is the same size as the spring and the head is smooth and you can get the deal the first 2 numbers on the head tell you after you take the head off
          it is bigger than the spring.
