Ridgid standard reel capabilities
  • Ridgid standard reel capabilities
    Hello all. Im seeking feedback on the standard reel camera. Has anybody had success with using the standard reel in 3" lines? I will be doing a majority of 4"&6" lines but do run across houses with 3" sewers. I have not purchased the camera yet since I haven't decided between the mini and standard. Unfortunately, it's not an option to buy both cameras right now. Im leaning more towards the standard because I don't want to cut myself short in case I run across a bigger line with a longer run. Thanks for any input.
    3'' is no problem with the standard full size reel. just don't try running it through a trap.
    Rick.
    • PlumberSteve
      PlumberSteve commented
      Editing a comment
      Thank you Rick.
    3" is no problem
    Hard to get through a closet 90? ...keep a shoelace handy or some nylon string to manipulate the spring to get where u want it..rule of thumb is you can get a camera where u can run a cutter...
