MICRO CA-350x (wifi)
  • MICRO CA-350x (wifi)
    Hi,
    it's my 1st post
    I try to use my android phone as 2nd screen to view footage from MICRO CA-350x by wifi
    but connexion failled
    message on my phone is "no IP adress given by MICRO CA-350x network"
    how proceed to solve it ?
    what is the static IP to set manually ?
    MICRO CA-350x firmware is rev 1.2
    Thank you by advance for your help
    Did you review the manual on how to enable the WiFi feature?
Name:	CA-350x Manual - WiFi connection pg 13.png
    Full PDF manual attached to this post.
    "It's a table saw, do you know where your fingers are?" ? Bob D. 2004
    http://www.cordlessworkshop.net
    https://youtube.com/@bobd.
      Hi, thanks for your post
      yes i already see and read this part of the manual
      note that there is no help file in the view app
        don't realy know how
        but help file just open and it is write to set ip 192.168.2.33
        I try it and let you know result
          with that setting it's work
          thank you
