Seasnake Termination wiring
  • Seasnake Termination wiring
    Hi All,
    I need the wiring details for the termintaion of a standard SeaSnake drain camera cable, Urgently
    Thanks in advance Guys and Girls, Sunny Melbourne ,Down Under
    Update
    Hi,
    I require urgently a Termination wiring diagram for See Snake standard and Mini Drain Cameras, I forgot to take pics of connections prior to dismantling and forgot which wires connect, I Know red, yellow, orange and red are kept together, but which wire do they connect to, and the white one connect to ?, and the shield one connects to ?, I have white, black and green on the camera whip, A quick response would be greatly appreciated, if you have PDF file or other please send to auscam@exemail.com.au,
    Thank you in advance
    Lenny
      Wiring
      Snatch,
      For the regular Seesnake match up the wiring push cable to camera whip; red,orange, yellow and blue to the white. White to the green. The sheild to the black. For the mini; Orange , yellow, red to the white. white to the green. And shield to the black. Check your wires for shorts Hope this helps.
      Jeff
        Legend
        Hi Jeff, Just the info I was after, your a Legend
        Thanks
        Lenny
          Re: Seasnake Termination wiring
          testing my avatar
