K-39af
  • K-39af
    I am thinking of purchasing the new Ridgid K-39af drain cleaner. Has anybody out there used one of these or have an opinion on them.
    Thanks
    DAND
    what are you planning to use it for?
    steve
      cleaning drains would be my first guess
      West Trail Mechanical Ltd
      www.westtrailmechanical.ca
        dan, the k-39 auto feed is not bad. i use it all the time. the only problem i have with it is that it will slip and not feed or retract with approx. 5' of cable left in the drum. so if you have a 25' cable, 20' will go in, but it will slip and you'll have to pull back the cable to get it to auto retract. i find that if i need to, i use the k-39 with the chuck adapter to pull it back or feed it all 25'. also the chuck works better on a tight trap or drain.
        the auto feed k-39 works fine for 90% of my use. plus you don't need to handle the cable like you do with the chuck feature.
        the regular k-39 is junk. good news is that the auto feed or chuck can be installed on a k-39 to upgrade them.
          my question was directed as to what it would be used for. run down a cleanout or a sink? remove a small hair or grease blockage or get a serious blockage removed.
          i have the k-39 with the slip chuck. a true waste of money. i only use it on bathroom sinks and the occassional washer drain where i can't get my k-50 in.
          and as always Plumber Rick has moved in with a voice of reason.
          steve
