Foot Switch
  • Foot Switch
    Ok Josh we talked about the "Foot Switch" on some other post a month or 2 back and now I have another one that split out. This one is only 2 months old??? Are we just buying HD quality tools? I`m having all kinds of problems with NEW stuff all the sudden. What's up? Is this K-7500 just gonna keep eating money? These are all new problems with new parts. I cant keep eating cables and Foot Switch's. I`d be more then happy to send in the last 2 Foot Switch`s so you guys can see for yourselves that they just split out for no reason. Kinda makes me look bad when I cant finish a job with out running to the shop for parts all the time
    Re: Foot Switch
    heres a link to the other post about the "foot stwich"
    http://www.ridgidforum.com/forum/sho...ht=foot+stwich
      Re: Foot Switch
      all clear. what is the temperature that your working in?
      in 26 years professionally and 5 years as an apprentice, i've only worn out 2-3 foot switches, air bulbs. that's because the rubber rotted at the barbed connection.
      i wonder if it's too cold.
      p.s. the replacement bulb is avaliable from general too. $5.00
        Re: Foot Switch
        Could you maybe just do some changing around of things and use a totally mechanical foot switch? Please see picture below. If you or someone you know could do a little electrical work, then I'm pretty sure this would work. Mostly they are used on small stationary machinery as the on-off switch. You have to keep your foot on it for the machine to run. I have a feeling that the Ridgid air bulb ones may need to start using GoodYear rubber rather than junk from China. Let me know if you would like more info on this one by LineMaster.
        Note: I totally forgot about water issues. This type of switch is OK for use only in dry areas. My brain just won't wake up today. :-(
          Re: Foot Switch
          I'm not sure I would want to use an electrical foot switch for a drain cleaning machine. The idea of the foot switch is it is an air switch so you are not working with an electrical switch on a flooded floor.
            Re: Foot Switch
            Good point
            You sure wouldn't want to use that around pools of water. Hopefully Ridgid has a better replacement part than the O E one.
              Re: Foot Switch
              I`m not going to buy another Ridgid foot switch till they fix the problems. I`m using one off my Cobra machine and if it holds up I`ll order one from them. The Ridgid foot switch is about 35 to $40.00 and only last 2 months Now to find a good 100` 3/4 inner core cable Hint Hint
                Re: Foot Switch
                I have an old burton 100 foot snake, I need to convert it and I am in need of an air switch, if anyone has an extra one please let me know, thank you kindly, Phillip. phillipcothran@yahoo.comhttp://www.ridgidforum.com/forum/ima...lies/smile.gif
                  Re: Foot Switch
                  I ordered mine off some website in florida. Its just a replacement part. I'm sure you can get them from any machine maker
                    Re: Foot Switch
                    Why not just convert it to an on/off switch? We do that on all of our 1065s and 300 machines.
                      Re: Foot Switch
                      There is no way in the world I'd operate a cable machine without a foot switch. I've been wrapped up enough to know that a broken arm would happen sooner or later.
                      www.ClinkscalesSeptic.com
                        Re: Foot Switch
                        That is a scary thought
                          Re: Foot Switch
                          i tried drian cabel directs foot switch and it was junk! spartans seems to be o.k.
                            Re: Foot Switch
                            Do much drain cleaning? I've never had a cable wrap around my arm. I have had them grab the glove before. Foot pedal doesn't help with that either though.
                              Re: Foot Switch
                              Allan J Coleman makes the old style Spartan foot switches still. Where the A/C goes to the petal then to the machine. I like it a lot.
                              I did make a electronic relay type switch where the pedal only had a 9 volt battery in it, and when you stepped on it it triggered the electronic relay to run the machine. I was able to run this pedal in a bucket of water and not get juiced. I also did a UL and VDE testing on it and it passed with flying colors.
