Merged - Drum v. Sectional Thread
    Re: Drain Cleaning: Sectional vs. Drum/Baskets
    798 jetter with warthog nozzel or the root cutter .4000 psi 18 gal.min. Life is good and we get $$.
      Drum or sectional?
      I am thinking of buying a machine to clean roots in a 3 or 4 " main.I looked at past posts confused as ever.What machine /cutters/cable would work best?Drum or sectional?Any advice appreciated.
        Re: Drum or sectional?
        What!? Are you trying to start a war!?
          OMFG!!!!
          Here we go cowboy! Diesel up the tractor and get ready to ride.
            What EXACTLY to you intend to clear with the machine?
            Will you be using it outside exclusively?
            What kind of pipe will you be using it in?
            What estimated distance?
              You there harley?
              Or are you a regular causing a little stir???
                • #23
                  OMG.......
                  • #24
                    This should be interesting.
                    • #25
                      No would be used inside approx 75' not really sure about pipe in old house.Trying to clean roots a once a year deal.
                      • #26
                        Save your money and call a PRO
                        you could always go to Homedepot and buy a 380 ...
                        • #27
                          Once a year you would honestly be better off calling in a professional drain cleaner to cable the line once a year rather than having a non-earning machine under the shed.
                          I don't consider myself a regular draincleaner yet but I would recommend you get someone to jet the line clear of roots & give a root treatment to kill roots also.
                          Might last 2 or 3 years or longer. Only real way to know is camera the line.
                          • #28
                            The machine I would recommend runs $2000.00
                            Anything else is not worth fighting roots with.
                            Better off calling a pro once a year, or better yet, dig it up and fix it.
                            • #29
                              Ok if you think about it this way you could just get a new sewer cheaper
                              Ridgid 60052
                              K-7500 Drum Machine with 3/4" x 100' IC Cable $2796.30 + Shipping
                              ridgid 73182
                              200 foot SeeSnake Reel w/ Color Monitor + VCR $8,647.34 + Shipping
                              $11,443.64 just to clean your sewer once a year and make sure it`s clean...hummm
                              Yea go fo it
                              • #30
                                I would go for both, they each have a advantage.
                                but I use my k-60 95% of the time...for smaller drains inside a drum machine is pretty good though..
