I'm sorry but I have to ask
  • I'm sorry but I have to ask
    --Ok here's the deal, I'm moving my business to Arkansas and all the statements and threads about sectional machines has caught my attention. I've been drain cleaning since the late 90s and have always used drum machines. Started off with Gorlitz, used Marco, General, Duracable, Spartan, Coast, Ridgid, Desert, and some homemade job I couldn't trust as far as I could throw it. They've all done the job, some took more work than others, some I'll never put my hands on again, a couple worked like a dream. I've only seen a sectional used one time in the past 10 years and it was pretty interesting. Here's where I'm going with this. Where I'm moving the sewer lines are pretty shallow and average 60-85 ft long. Which is more efficient in this situation, sectional or drum?
    --There's also alot of, and I do mean alot of, orangeberg pipe still in the ground. Now, given the increased rpms of a sectional, is there more of a chance of getting outside the orangeberg or snagging up with a sectional?
    --There's also alot of clay tile and where there is clay pipe, there's always roots, but since the lines are so shallow, alot of the time they lack any true fall. So of course I'll be getting alot of sludge lines. How well do sectionals work on sludge lines? Or should I even worry about how well they work, just get the roots out, make another pass for good measure, and put a blow bag in the line?
    --How bout 3" cast iron lines? There aren't a whole lot of them here going to the city sewer but there are enough to consider.
    --I know for those lines that have been forgotten or haven't been found yet, I have to jump on the roof and throw cable down the vent, leave the machine going, go sound it out in the yard, and locate it. Most of the time you can feel the vibration in your feet as well as hear it very well. So I guess the big question is, is it worth for me to purchase a sectional or should I stick with my drum machines?
    Thanks for your responses! I know ya'll have talked and talked about sectionals. I just needed to give you some specifics and hear what you had to say about it before I went off and made a big purchase.
    Re: I'm sorry but I have to ask
    Sectional cables are great for sludge, muck, grease...mind you not as good as a jetter would do, but next best think IMO. If there is alot of Orangeberg pipe, i would worry. I used electric eels dual eel sectional machine. I wouldnt dare use it on orangeberg....I will only use sectional cable on commercial properties, or from an outside cleanout after the line has been openned to remove tree roots. I use a Spartan 2001 100ft of cable for resid. inside and outside on main san. lines..100ft has never let me down...the cutters are great...I have used it over and over again on orangeberg pipe, with no problems..just have to be carefull how you run it...its all about the feel...There are advantages and disadvantages for both... IMO drum machines are better for feeling a clog or obstruction...I was trained on and used sectional cable for 5yrs nonstop, for all drain applications, but where im at there are also alot of curb traps or front yard cleanouts...When i switched over to the drum machine, i fell in love with it...only problem i find is taking it up and down steps...IMO stick with the drum machine
    Greg
      I only use Drum machines. My best of all times is the K-7500.with 125` of 3/4 cable
      I`m going to get a K-60 but only to work in basements so I don't have to call one of my helpers in to move the K-7500 up and down the stairs.
      Sectional machines take to long to set-up and put-up. The K-60 will be the only one I will ever have in my Trailer
      Now take that for what it`s worth as it`s only my $0.02
      Oh and for locating those lines underground I use my recon locater
      I`v been working in sewers since the mid 80`s I know the tricks
      You can run a small drill type cable down the vent and do your locating to dig and install a clean-out.
      BTW, I have one of my old locaters for sale
        I prefer a sectional(1 1/4") but I use a drill to run it. With the drill in my hands I get a lot more feel for whats going on. I have a nice rod runner machine to run the sectional but have only used it once and I often run well over 150'.
        With a lot of old homes in my area the sectional is much easier to get in and out of the basements.
        Now if I were in an area with a lot of outside c/o's I think a drum machine would be easier.
        I think it has more to do with what your use to using. I think I've only used a drum machine 4 times so to me they just don't feel right.
        One advantage of a drum machine I can think of is its one continuous cable. With a sectional I often find myself only able to go in one section at a time, so every 10' I have to stop, unhook the drill, attach the next section, unhook that section from the others and, reattach the drill. After about 100' that gets pretty old.
          I'm with Drain Medic and All Clear on this on too. Stick to the drummy.
          I used to hate clearing sewers when it was Orangeburg.
          Stay away from the root cutters
          Orangeburg made me a rich man when it was time for replacement.
            I just did a replacement yesterday.
            120` in 2 hours and $250 in parts and we walked away with $2200.00
            you just gotta love Orangeburg
              All clear, sounds like you gone flat rate and you put the cheapest type of pipe that they make in for your customer. Nice guy
              As far as a machine for snaking lines, you could go with the K-60. /It will work great for roof top kitchen drain stoppages basement locations, And the 7/8" cable can be used to unstop main lines. If your having to much problem getting down the 4" line,then the pipe needs replaceing anyway IMO
                ever since i was told to try a sectional, my drum machines have gotten jealous. i still carry a 7500 in the truck, but i also carry the k-60 and k-50 along with 2 jetters and a few k-39's.
                i would have to say that the machine that is getting the most use now is my k-60 it will do lines that my 7500 with 3/4'' cable can't. such as roofs, tuff access, and styrene pipe and fittings.
                i love that k-60 and i need my 7500 for brute strength, my 1.25'' machine and cables stay at the shop until all hell breaks loose.
                try the k-60 and if you don't like it, i'll buy it from you
                more later as joey is bugging me to go to dinner
                  I like my k-60, scratch that--love it. I've used the spartan 1065 from work and I also have a k3800. The reasons why i like the 60 is as follows:
                  --clutch gives you instantanous control over the cable, less chance of over torquing the cable, once you lift the handle, any built up torque goes away.
                  --faster- the setup time is longer but the overall process time is quicker. how fast can you push a cable in and out of the hole? pretty quick.
                  --the sectionals give you an indication of how far in the pipe you are, drums don't have that.
                  --take up less room. my 60 with all the guide hose, a 90' reel of 7/8 cable, a 75' reel of of 5/8" cable takes up less room than my 3800 with a big and small drum.
                  --lighter, when i do a roof I leave all my cable connected and tie it to a rope which i tie to me. when i get to the top, i pull the cable up as needed, i can take the 60, guide hose, extention cord and the rope in one trip.
                  my boss hates ridgid, he's a spartan guy. Every week I change his mind a little bit more when i do jobs that the rest of the guys can't do. Not that he'd ever admit that.
                    now daddy, you made that deal with me
                    Robert
                      robert, the deal goes for you too. but what do i get when you decide to keep it
                      since this is a suckers bet, i'll let it ride.
                      ben is 100% correct. the sectional machines have practically no overrun as there is no drum to continue running like a flywheel. the sections will stop the instant you let go of the handle. the cable sections are more flexible and therefore they will get past tuff turns and even traps.
                      the open wind cable acts like a giant continuous auger and will grab roots and baby wipes. also it augers the sludge out.
                      i very rarely use my rear guide hose and therefore am almost as fast with the sectional as i am with a drum.
                      when it comes to weight, the sectional is the hands down winner.
                      mark is the one i have to thank for pushing me over the edge and buying a sectional machine. problem is i didn't know he meant only 1.
                      as of last count i now have 8 thanks mark
                      by the way, when you get your's, you can thank me
                      your welcome ben
                        Another great thing about the k-60 is if you running the machine from the roof you can adjust the jaw setting to turn the cable, so you are able to go down and hear the location of your cable. This is great for a one man plumber. The old way you had to tie off the handle and hope it held. The best would be use a locator but this some times is faster. IMO
                          Well, a drum machine should be alot quicker. I use a Spartan 300 which holds 75' of cable. There are two nuts to loosen and remove the drum from the machine. Then I use a rope to haul up the rest of the machine. I usually get the line open in the first 75', if not I have an extra drum. I can often lower the whole machine off the roof with out taking it apart.(depends on the roof though)
                          Now how hard is that?
                            It's your back not mine. The k-60 is easy to work with on the roof, you carry the machine up then the cable 90 feetready to use, very easy to know how many feet you have put in. I would only use a drum machine on a inside bathroom job.
                              a 300 spartan is quicker than a sectional on the ground when you just wheel it to the c/o. but on the roof, when you have to take it apart and hump it up is not even close. i too own a spartan 300 and it's basically a scaled down 7500.
                              i know that i can easily carry the 60 with 1 hand and the 75' of 7/8'' sectional with the other hand to the ladder. still need to make to trips up the roof as i don't climb without holding on with 1 hand.
                              plus how would you keep the 300 from rolling off a pitched roof?
                              believe me, after using both machines you would be much happier and proficient with the k-60 on a roof than a drum machine. unless that roof is a flat roof with an elevator access to it.
