Fernco Pipe Patch
  • Fernco Pipe Patch
    I just had dinner with a Fernco Rep and I'm doing my first pipe patch in the morning. In 15hrs I'll be a factory trained installer.
    I've been driving myself nuts since last week trying to pull this all together and at the last minute everything fell into place.
    Re: Fernco Pipe Patch
    Ummm, question, what does a fernco certification allow you to do? teach you to do? I personally have never heard about Fernco certification.
    Robert
      Do they do street main sewer saddles
        http://www.youtube.com/watch?v=8GvjwQhfwCc
        Shortest video I could find.
        No dig patch repair.
          That video makes it look like the pipe ID is significantly reduced or was it just the camera angle as they say in Hollywood?
          This is what they say in Hollywood isn't it Rick?
            This is just like Permaliner.
            Liner equipment, the id is smaller, but not by very much.
            Thanks for the cool video, glad to learn Fernco does this
            Robert
              Yes. It is just like permaliner but half the cost to get started.
                Neat system let's us know how it goes on your repair.
                  i've looked into the fernco system for a couple of years now.
                  the biggest issue is the push rod system they use. it's a joke. let me know what fittings you have to push it through and how far it needs to go.
                  i've discussed the issues with my fernco rep and he would be thrilled if i come up with a better push rod/ air delivery system. i know i can, but just haven't spent the time to do it. i've already got the idea in my head and can make it at my buddies machine shop.
                  it's also approx. $215. for a 4'' x 2' patch kit. plus the equipment.
                  not a real bargain.
                  gene please take pictures and let us know the entry point, fitting and distance from a real pros perspective. salesmen are not pros.
                  thanks,
                  rick
                    Rick,
                    Can you negotiate fittings with this system? I assumed it was for straight shots going from man hole to man hole.
                      mark the idea was to push it through a combi and the asst. pipe and fittings to the premeasured location determined by your camera inspection.
                      in real life the push rod assy is nothing more than 1/2'' sch. 80 pvc with air quick connect fittings every 5' for joining. this is the real stumbling block for me. i know i can redesign the push rod assy. and make it work like a seesnake does.
                      that's why i am asking ben for his photos and specs on the job.
                        Rick,
                        It seemed like all of the patches I saw videos of went from man hole to man hole.
                        It seems like they would be better off pulling with a SS cable than pushing with PVC. They could still drag an air hose behind the patch to inflate the repair.
                          mark with a cable, that would require a downstream cleanout.
                          with a push rod, all that's needed is 1 cleanout.
                          the push rods are stiff, but too cumbersome with the air fittings.
                          gene will be a good judge of the product.
                            Like I said the examples I looked at had man hole access from either side. I thought this was just mean for municipal lines, Is it also meant for private laterals?
                              Never mind I found on the web site they make 3" though 10" packers so it must be used for laterals as well. I need a new lateral at my place but I think I will go with PVC or SDR replacement.
                              mark
