Jetting damage foam core pipe?
  • Jetting damage foam core pipe?
    Foam core pvc is gaining popularity around here. Will jetting damage these pipes?
    Re: Jetting damage foam core pipe?
    ben, were you reading mine and roberts roots post last night?
    depending on the psi and gpm of the machine. as the pressure goes up, the potential of damage can go up.
    drain jetters typically don't exceed 4000psi at the machine. then minus the hose friction and length, you might deliver only 3700# at the nozzle.
    there is a very good test with photos on the warthog site to show pressures, psi, material, & exposure time.
    i find that in plastic, the line clears so quickly that it's never been an issue. when i camera lines i see the tell tale signs of the snake and cable wear around fittings. i haven't seen signs of a jetter wearing the pipe or fittings.
    but the day is not over yet
    ben is the wife going to let you buy a jetter? am i in trouble now
    need some recommendations
      Rick, I didn't see your guys' post last night. Just wondering about shooting a whole through a foam core pipe. The pvc veneer is extremely thin. My next big toy is a see snake. The jetter will come afterwards. I told my wife that Robert is pushing the see snake. HAHAHA. Just kidding
        Me and Pop like to use Foam Core..but not in underground situations.
          I am in the market for a new jetter. It will be my first one. Should i go portable or trailor. Gas or electric? What is the best brand..
            Gas fore sure. Get the biggest one you can afford. The one we use puts out 4000psi and twenty gallons a minute.
              Depends on what you want to use it for..Resi, or commercial, or both. Size of lines you want to do...I have a trailor and mini. The trailer i will only use on 4-10in pipe. The smaller jetter for 1 1/2 to 4in. They both work great for the applications. If your doing just residential, then i would recommend a mini, maybe 3000-4000psi, 5gpm, that will do just fine, 1/4in hose, at those pressure you can still cut tree roots out of lines. either or, they will both do a good job, obviously the trailer will have better pressure and better flow. Also would depend on how often you would use it.
