Hot Women of Ridgid
  • Hot Women of Ridgid
    now I knew that would make you look
    Ok Now back to that question I asked 2 months a go and never got a reply.
    Why can I NOT get any new cutter bolts for my K-7500 Cutters ? They seem to be getting softer and wearing out real quickly!
    I need to replace a bunch of em as they are falling off in sewers left and right.
    Re: Hot Women of Ridgid
    not fair all clear
    i've had the issue too. i've welded the groove and then dremeled the slot back into it to take up the slop.
    i feel that the half turn ecentric screw on the coupler is a weak link and doesn't provide the best connection. the spartan uses a roll pin that is much stronger and secure. problem is it's much slower to change the cutters.
    i would like to see an allen bolt. i have drilled and tapped an end to accept an allen bolt and it worked fine. you won't loose an end when it's secure.
    maybe on your next post, you can announce a free giveaway
      I was thinking about welding em up but I was thinking it might screw up the half turn eccentric screw with a hard weld?
      If I could just buy a box of new bolts like I can cutter blades I would be happy.
      I`ll be using that Free Give-A-Way thing soon
        On my spartan cables I have pins I knock out with a special little punch tool, I hate allens because they tend to get stuck and never come out.
        Spartan has it right, the pins rock
        Robert
          ,, are these the hottest women Ridgid has to offer?
          Oh, I'm supposed to actually read what's posted?
              I keep wondering when Rick will change his avatar
                Josh
                can you check in on the bolts thing?
                  I'll bet this thread gets 1000 views but will barely get 15 posts
                    what, you don't like my k69 snake 1 mistake and you're dead
                    i will pose for a new snake shot in costa rica in november.
                    maybe an anaconda
                    or maybe a crocodile. now that steve irwin is gone
                    or it might be my photo shoot for the ridgid calendar april pose
                    you'll know sooner or later
                      all clear.. by bolt do you mean the lug that is welded to the tool. or the bolt that does the quick disconnect where you shove the pin in.
                      Please clarify a bit and I will talk to the product manager.
                      Josh
                        hows that????
                          The only post I 'read" was Bob D's.
                          Thanks alot "All Clear".
                            Sorry but I had to do it as no one would even reply on the old topic
                            Now Josh, hows bout some bolts?
                              I forwarded this off to our product manager.. awaiting a response.
                              Josh
