Roots In The Middle Of The Street?
  • Roots In The Middle Of The Street?
    Installed missing cleanout 5ft in from curb. Sanitart dist. did freebe camera to house and main. roots near main. small junipers 20 ft from this in yard. No old tree trunks,or trees in this area. Where could the roots come from? Will cut roots and follow with rootx as You have discribed in this forum. Thank's all for Your wisdom.
    Re: Roots In The Middle Of The Street?
    I believe you can cut down a tree and the roots will keep on growing, never ending roots.
      I've had roots come from trees as far as 30 ft away. I've heard roots keep growing 5 yrs after the tree is cut down. I've had more roots come from shrubbery next to the house than the tree out front.
        Correct, tree roots will grow under ground for up to 8-10yrs after a tree has been cut down.
        Also i see alot that you can go from the house all the way to the curb line and be root free, but as soon as you get near the municipal connection, tree roots will start to intrude. Usually because the municipal lines were put in 1st, then the house lines were tied in and tree roots will find there way in the joints right there, where the connection from the house line meets the municipal line.
        Greg
          Not sure if this is 100% correct but as I understand it the root system is twice the size of the canopy of the tree.
          "Correct, tree roots will grow under ground for up to 8-10yrs after a tree has been cut down". Even if stump is removed?
            Thank's Gene I'll be pulling The Junipers with My backhoe ,when I work in The same hood in a couple of weeks.I HATE JUNIPERS! There a fire hazard,harbor rats,Eat sewers. Local town just wrote an ordanance about there distance to houses! Don't believe this? I'll post this next week.
              Take care when pulling as the roots can and do wrap themselves around underground utilities. It would suck to pull out the stump and find a power line attached.
                Do some research on it, but thats what i come to find out..We had a customer faithfully evey year for 9 after they had their tree cut down due to root intrusion...After the 9th year, and cleanings and root x's, there were no more roots at all.
                  Wow I had never heard of this! I bet You were doing Your best to look sad!
                  You and Rick ,Trying Your best to look bumbed out at MASSIVE ROOT INTRUSIONS. Kinda like My uncle The Irish Funeral director,Trying to look sad at a $40,000 funeral !$$
                    Yeah, if the tree is removed, the roots still feed and the sewer will still have root problems, many times, the customer is miss-informed and told if they remove the tree, the roots will "go away", sorry, not true, they still feed, the best way is to just replace, re-line, repair the sewer, or just plan on snaking or hydro jetting on a schedule. I have had many lower laterals full of roots, and the saddles, in the middle of the street, many times, have had root problems, the tree dosen't need to be over the sewer to be a problem.
                    Robert
                      Thank's Robert , These folks are family ,So I'll take My antiquated equept. with My limited experiance over there once a year. Hopefully We'll share a grandchild one of these days
                        As I understand it, if you cut down the tree and leave the stump the roots will continue to grow. If you remove the "heart" of the stump this will kill the roots. Are you guys saying that even after the "heart" of the stump is removed the roots will continue to grow? I'm just wondering as I may be one of the ones miss-informing my customers.
                          If you want to kill a tree, drive a copper pipe into it. Done within a year
                            I've heard a couple old timers mention that.
