Going around corners
  • Going around corners
    Guys
    I have been experimenting with attachments on my k1500 and have made up a universal joint that goes between my cutter and cable to go around 90 bends.
    The only trouble it broke the other day but I was able to retrieve it.
    I now have put a larger more robust fitting and it looks almost indestructable.
    How do you guys go about this type of work.
    I am looking for some thing similar for my jetter that enables me to go around or down a right angle bend.
    Has any one seen anything similar?
    Re: Going around corners
    I`v never had a problem with 90`s
      Sorry guys to mis lead I meant going a square junction not a 90 degree bend.
      Cheers
      greg
        I would never try to make my cables go through a "square junction" even if I don't know what one is.
        The word "square" tell`s me that there's no support for the cable to make a turn.
        What is a "square junction" ?
          You mean like a tee fitting? A "junction" shaped just like the letter " T"?
          If so they are called "drop heads" but they are made to drop down. I don't know how good they would be to control which direction they went as far as left or right.
            Re: Going around corners attention Gene
            Guy
            They are Tees horizontal and vertical
            Could the drop heads be used on the vertical Tees?
            Are they available from ridgid for a k1500?
              yes they are made for vertical tees.
              I don't know if Ridgid makes them
                This one is a Ridigid 63065
                it fits c-4, c-6, c-6IC cables.
                Not sure this is the one you need but it gives you something to go on anyway.
                  Greg
                  Are you by any chance talking about a cross fitting about like in the thumbnail picture?
                    Attention Gene
                    Attention Gene
                    That is very similar but they dont make them to go on a k1500.
                      attention Woussko
                      Its is like a TEE 3 outlets with the drain cleaner entering the middle outlet and dropping downwards.
                      Cheers
                      Greg
                        greg, with a tee like you described, i don't think anything other than a better cleanout would work for a 1.25'' (35mm?) cable.
                        unless you know the distance of the tee, it would be hard to control the drop. plus it would have to be a massive joint to hold up to the beating of a large cable.
                        can't you camera the line and extend the "T" to the surface for easier cleaning?
                        we also have T's that we encounter typically near the sidewalk/ curb. fortunately these are called a sanitary tee and have some direction to them.
                        there are very old ones that were more straight tees and these too can be very challenging.
                        if i can't get through with a cutter, then i use a flexible leader/ whip to attempt to clear the line. then camera it to locate the problem and install a proper tee and cleanout.
                        any chance of taking a picture of the actual fitting you're running into?
                        is it a fitting still being used or is it an outdated fitting?
                          Next time I get to dig one up I will take a photo they are outdated clay pipes.
                          Most of the time we do locate with camera and dig up then put in a riser to top to enable cleaning from above.
                          The uni joint is approx 1 1/4 inches in diameter as my orignal one was 1/2 inch and broke in the line.
                          I will show you guys what I am talking about when I get a few photos together.
