Cleaning Cast Iron Pipes
  • Cleaning Cast Iron Pipes
    Hi,
    Was hoping to get some opinions on cleaning old cast iron pipes.
    My Situation.
    I have about 120m of CI drains in an old mining office complex that has been recently re opened that are not in the best of shape, I have had a look with a camera and there are no roots but the pipe has corroded which is causing blokages.
    As i can not renew the drain (it is under the floor and encased in 3ft of concrete) what are ways and approx costs for gear (i have a K1500) to clean the pipes up.
    Cheers,
    Tobes
    Re: Cleaning Cast Iron Pipes
    Originally posted by tobes View Post
    Hi,
    My Situation.
    Cheers,
    Tobes
    I would try maybe a hydro jetter, low pressure to start, and turn it up from there, using a camera to check your progress.
    A cable machine isn't really going to do much, maybe spin the debris around, you can use a cable machine, and run a hose and the fixtures at the same time.
    What was running through these pipes before? human waste, oil's, chemicals, sludge, grease, once you determine the type of debris inside the pipe, you will then choose your appropriate jetter head or, if you choose, cable blade, but like I mentioned before, the jetter will be your best bet, with the camera for visual inspection.
    The last suggestion, the most expensive, would be the liner or pipe bursting options, permaliner is one, a sleeve is inserted in the pipe, rehabilitating the line, study up on these technologies to see which one is best for you
    Robert
      I usualy use a heavy duty spiral root cutter (use an old one as it's murder on the blade) followed by a jetting if needed.
        Use a cable machine with a knocker on the end then jet the rust and corrosion down the line to the city main. Some jetter even have knockers but you still have to jet the rust and corrosion down the line when your finished. What I`m saying is it`s gonna be two trips down the line either way you go
          120 meters s a long way if you only have 1 cleanout opening.
          if you can split it into 30 meter sections, the k1500 with chain knockers will do a good job at beating on the pipe. then you need to flush it out downstream. a jetter running from an open line downstream and back up to the pipe will help wash and pull the junk out to the open pipe.
          a slow process, but depending upon your condition, it might be the only practical way.
          what size pipe is this and how many cleanouts do you have? is it a straight run? does it pick up multiple connections/ tees?
          a liner is only as good as the original/ host pipe. pipe bursting is good until you have tees to connect to.
          need more info.
            I imagine if it is at a mining office it goes into a private disposal system but a jetter should help some. As far as lining the pipe I'm not sure how well that will work if the pipe is in cased in concrete.
              incased in concrete,I don't understand,I guess I don't understand liner install process.I was under the impression everything was done was internal
                He stated the pipe is encased in concrete. To line the pipe you do pipe bursting which assumes you can pull the burster down the line displacing the old pipe. If the pipe is encased in concrete you may not be able to displace the pipe because of the concrete.
                  mark, i think robert mentioned a liner and i mentioned pipe bursting.
                  for those interested here is a very brief explanation of the process.
                  the liner, (epoxy impregnated sock) is inserted into the exisiting pipe and inflated. problem is the condition of the original pipe is duplicated. also the tees would need to be reinstated. probably not very feasible.
                  trenchless/ pipebursting is total pipe replacement. host pipe is only a conduit to allow the bursting head to be pulled through. if the soil is no expansive or concrete encased, then it won't work. also tees would need to be exposed to reconnect to. typical pipe material is "hdpe" high density polyethylene.
                    Hi,
                    Cheers,
                    Tobes
                    You sure came to the right place for opinions.
                    Bruce
                      Bruce
                      Yea but my opinion is the only one that counts
                        That is very Sylvanistic of you.
                          Hi Guys,
                          Thanks heaps for that, much appreciated.
                          I will give a try with the knocker and jetter, will have to purchase both as there are no contractors close to where i am with one of these, do you do any prefilteriung of the water going in as the calcium/mineral content can be a bit high around these parts.
                          Cheers,
                          Tobes
                            Thanks
                            Rick
                            I understand how they both work now I think I need to have a look around and brush up on my drain cleaning info.
