K380
  • K380
    will a K380 hold 100 ft of 1/2 cable?
    Re: K380
    The specs only say 75' In practical use there may be someone who could get it in but I doubt it.
    josh
      Re: K380
      75' is correct.
      start off with the 75' and then add a 25' section when needed.
      i hope you don't plan on snaking out a main with a 1/2'' cable.
        Re: K380
        75' is correct.
        its for 2" lines. was asking because I have a 100" of 1/2 was just curious if it would fit in the drum. I also bought the feed attachment. I don't usually do drain cleaning, I bought this for an emergency I had to take care of on a weekend. It came with 3/8 cable which is really lame. was hoping maybe someone could let me know if they ever put 100 ft in a drum machine that small. That way I wouldn't have to try and put in in then have to pull it all the way out again. Is there a way I can cut off 25' then add the necessary cable couplings to extend it if needed?
