Tile Probe ??????
  • Tile Probe ??????
    More than once this tool has been mentioned. Can You please describe it?
    My guess Its' a 14" steel rod 5'long with a wood T handle. Also any tips to using it would help
    Thanks' Tool
    Re: Tile Probe ??????
    I'm assuming you meant 1/4" rod?
    They are made of a variety of materials and you probe the ground looking for the sewer line.
      i also have a 1/4'' carbide tipped drill rod that's 5' long. good for hard soil and lots of probes.
      i also made a high pressure jetter style probe that makes a 5' deep hole in seconds.
      tool weld up a piece of 5/16'' cold rolled steel to a 3/4'' pipe handle. install rubber bike grips to protect from a shock and sharpen the end of the probe.
      this will work fine on med to soft soil. on the hard stuff you need a drill or a water probe.
        I like to look for one thats insulated smoothly.I used to use one that was insulated in fiberglass,the finish was irregular and did not penetrate as well as good ol' steel.Also check to see if the design of the pointed tip is cupped to retrieve matterial from the product you have made contact with.
          I may be wrong on this but I think using a steel probe is an OSHA violation.
          I think they require a fiberglass one.
          BOBD do you have any info on this?
            Thank You all, Yes I meant 1/4" steel
              tool, i think 1/4'' is going to be way to flexible and will bend/ kink. my drill rod is 1/4'' and is made of a flexible drill steel. but it designed to flex with the drill spinning it.
              i can check today, my real probe for a thickness. or try a 4' section of steel rod and check the flex. a bent probe is useless and will be too much friction pushing in.
                Thanks Rick .I was at the shop today and welded one up. Used 1/4" hot rolled 5' long I" handle
                20" long with bike grips. Ground a wicked long tapered tip. just tried it at home seems ok.
                Again won't get used much. Our work is back into carpentry for a while. Tool
                  http://www.tandttools.com/Mighty%20Probe.htm
                  This is would suit both parties.
                    Do you actually use this probe with a drill? If you hit something with it, wouldn't it be to late?
                      fortunately i've never hit anything
                      i verify my location first with a camera/ locator. i just probe for the heck of it.
                      today a probed right through the 4'' sewer jim cap that was buried. i saw the probe on my camera
