k-1500
  • k-1500
    i am look at a used k1500 the guy said it runs good but he dont know if the clutch needs adjusted or replaced. he said it dont make any noises but you got to push a little harder to spin cable. my q. is what do i look for when buying it is there a adjuster or will it need replaced if it does need replaced is it hard to do and what do they cost for part. thanks for any help
    Re: k-1500
    not really a clutch, more of a 3 piece jaw set. approx. cost $40.00
    there is a adjustment at the rear next to the rear guide hose.
    i would be more concerned with the condition of the cables.
      Re: k-1500
      there is 4 cables all for 400 dollars. where is the best place to get parts for it at thank you
        Re: k-1500
        is the part called a jaw assembly is that the part that am looking for. is it in the front, the adjustment
        is in the back where would i start first to find out what it is. do all k1500 units us 1 1/4 cable i never thought to as him if it had that size cables. thank you
          Re: k-1500
          http://www.ridgidparts.com/rtctable.phtml?id=521
          look at part #7 jaw assy.
          there is a jaw set for 7/8'' cable, but the machine is a monster for the 7/8'' cable.
          $400 is a bargain for the 1500 and cables.
          the adjustment is part# 33. loosen the set screw and tighten the part 33. this will allow for take up on the jaw assy.
            Re: k-1500
            I have jaws for 5/8", 7/8" and 1 1/4" which came with my K-500 and I believe they are interchangable with my K-1500. Of course I don't know why you would want to use them unless you only owned one machine.
