anyone use a rodder?
  • anyone use a rodder?
    Is anyone experienced with a rodder? I've never seen one, let alone used one. Interested to hear about a different machine/technique and what it's good for if anyone has that experience.
    -Alex
    Re: anyone use a rodder?
    With today's cable machines why would anyone want to use a rodder?
      -Alex
      I've never used one before but I believe they are best suited for mainline stuff running from manhole to manhole.
        no idea... thats what I'm asking
          Wow it is for 8" through 24" so I doubt any of us would use it. I do see them for sale on eBay every once in a while. Here is the owner's manual.
          http://www.ridgid.com/ASSETS/A3AA5BA...Rodder_Man.pdf
          Okay I read the manual and this thing is scary and it takes two guys to run the thing. However, I'm wondering what it would be like to run a 12" corkscrew.
            rodders are not designed to go around bends. just getting them into the manhole is fun enough.
            i don't even own one and don't plan on it, yet
              Hope I can shed some light on this question. As a utility Lineman I used several rodding trucks over the years. They are best suited for heavy duty ducts ceramic, cement, metal and if you're careful pvc.. Basically the 1/2" steel rod is sandwiched between two sets of rollers and in addition to moving in and out of the machine the coil can be spun on it's drum. A rubber reinforced steel hose of about 15' leads off the back of the truck and can be secured to the duct in a number of ways. A slow oil drip is added to the rod as you power it forward. A pressure guage lets you know how much resistance the rod is experiencing. If you hit an obstruction, you pull back a foot or two, put a spin on the rod and go forward slow! These machines are very strong and very dangerous, best to have one or two people at either end with good walkie talkies. Try to know your distance the machine has a counter. Frank.
                Check this site out, im pretty sure there are a couple of pictures of old rodders in there, plus has a ton of other pictures....its a really cool site.
                The History of Sanitary Sewers
                  Best way to clean 8" and up is a big jetter the rodder is out dated
