Right angle grinder
  • Right angle grinder
    A while ago some guys were talking about using a right angle grinder to cut through cast instead of a cracker. Thanks a million. It worked great for me today. One of those things I couldn't believe I didn't think of on my own. A lot cheaper than a cast cracker also. Now to find big enough wheels to make a pass from the top all the way through 4". No problem with the 3" today though.
    Re: Right angle grinder
    Get a rescue saw. That's what usually use. http://www.stihlusa.com/construction/TS400.html
      the 14'' saw will cut 5'' o.d.
      the chain saw i have will do 14'' od from 1 side
      funny story a couple years back.
      i had my buddies son helping me for the day while he was out of school. i had to install 10 cleanouts and snake the lines 6 hours since the pipe was old, i used my 14'' saw with an abrasive wheel. of course people were still running the water down the waste lines. i put on my tyvex disposable overalls to keep me dry problem was they tore right down the middle exposing my zipper to my plumbers crack what i didn't realize was the cast iron grindings were rusting onto my pants/ jeans under the tyvex.
      of course it looked like i cr@pped in my pants. my helper sort of told me that i was dirty, but not until we had stopped at costco for a hot dog and coke, walked around the store and even sat on the display couches, did i realize how dirty and nasty i looked. to this day those pants have never come clean in that region, and i'm too embarrassed to wear them in public.
      now back to your issue. just cut a window into the top of the pipe to allow for the grinder to get inside of the 4'' pipe and cut from the inside out. works great for me in a ditch.
      glad to see you're posting plumbing talk say hi to john tell him it's sold
        I don't cut much iron, but when I do I use a 4" angle grinder with a diamond blade for tile. like buttah. can't get all the way thru anything in one swipe with a blde this small, but I dont cut much iron. I put a nh band around it for a guide to make a straight cut. works beauty on clay drain tile also.
          I've had this -----> 14" Makita for 4 years now. I use it to cut through 4" CI using an abrasive blade.
          I bought a diamond blade on e**y for $60 bucks that works like a charm for cutting through concrete.
          I also bought the saw on e**y brand new in the box for $700 shipped. Back then most of the stores wanted $1000 for em.
          Now Makita makes a 16" saw.
          Rick, you sold the S300?
          Tracy
