Installing cable
  • Installing cable
    When installing cable into a drum machine, which direction do I load it? If I clamp the cable at the 12 o'clock position, looking from the front, does the cable then wind to the left (10 o'clock) or to the right (2 o'clock). The forward direction is drum turning counter clockwise looking at it from the front.
    Thanks for your help
    Re: Installing cable
    um..... is this for real?
    just shove it in thru the same tube you pull it out of when using it; it winds itself in the drum. don't bother to clamp it; until you get down to only a couple wraps left in drum it doesn't matter.
