Drain Cleaning Professionalism
  • Drain Cleaning Professionalism
    Do you use blades on your drain cleaning machines?
    10
    Mainline Machine Only
    40.00%
    4
    Top Snake 1/4" & 3/8" Only
    0.00%
    0
    No Blades At All, Only On The Mainline
    0.00%
    0
    I Bend My 1/4" & 3/8" Cables A Special Way, never had a problem.
    60.00%
    6
    The poll is expired.
    Robert
    Re: Drain Cleaning Professionalism
    Yes.....
    with the exception of smaller drains. Slightly bent open hook.
      Vote away fella'z, I will be open and truthfull, I use a blade on my 3/4" mainline only, my 3/8" and 1/4" have a hook, and on my 1/4", I have it bent a special way to pass traps easily.
      I cannot remember one specific call beck on a drain I have cleared. I have actually recieved compliments on trips back for repeat customers, I ask how their drain is to follow up on the last service call, and they explain no problems. I had one the other day, he stated it never drained so good. So it is what it is and to each their own.
      Robert
        Which option do I choose if I don't bend any cable's at all?
        Proud To Be Union!!
          Spartan 2001, I use C cutters, or any cutter i need all the time on that machine
          Spartan 100, Rarely do i use a cutter, but i do like using cutters on that machine to get thru floor drains
          Spartan 81, I will not use a cutter at all.
          On all of these machines i make a bent leader so that the cable will scrape the entire diameter of the pipe.
          Sectionals i will use a bent leader with a head to go back on traps, and work with cleanouts. I will use a straight leader with a head going thru traps with a sectional
            Hmmmm, crappy pole I guess, well it is my first one
            ok then, you don't bend at all? you must use a blade then???
            If you don't do either, then that could be a problem......
            Robert
              At the risk of sounding like an a** yet again, What's a top snake?
                I use the general super vee, excellent top snake.
                great for showers, tubs and lavs.
                Robert
                  OH. o.k.
                  Now I'm really going to look like an A**.
                  My name is Gene B. and I own a power spin. There I said it. Admitting I have a power spin is the first step.
                  I like the Super Vee but its hard as hell on my hand,wrist, and forearm. Too many years of pipe laying and visiting mary palmer and her five sisters I guess. I can run a Super Vee about 5 mins max, then I can't feel my hand, after that it's just a short time before I can't even hold on to it.
                  Anyone make a machine thats like a power spin but built as good as a Super Vee?
                    I use the bulb auger for my 5/16 cable with the end being bent, helps get through traps like this. For everything else, I run blades. Still waiting to see a pic of this special bend of the cable you talk about.
                      Originally posted by DUNBAR View Post
                      Yes.....
                      Same here
                      The drop heads always break on the smaller cables anyway, so the first thing I do cut them off and put on my custom kink. It's easier to get the hair off the end off a bent cable than to pick it out of a bulb head. I get really grossed out doing that
                      I use a flat blade not the 4 sided one on the mainline cable
                        Originally posted by plumberscrack View Post
                        Same here
                        Crack, I think you forgot to vote number 1 or number 2 would fit your
                        answer
                        Robert
                          answer
                          No I voted #1 earlier, just didn't post anything until now. I didn't want to vote too soon and look like a fool when the results came in
                            LOL, I left it private so no one would feel obligated to vote one way or another, this way it's all a secret, so everyone can be real honest
                            Robert
                              I use blades or bulbs on all the snakes except the one that doesn't take it. It is a 1/4" cable. I don't own a power spin either
