Cleaning Drains Through Roof Vents
  • Cleaning Drains Through Roof Vents
    1
    Re: Cleaning Drains Through Roof Vents
    New propertys would have clean outs installed per code so either way you should not have a problem
    THE GLASS IS ALWAYS HALF FULL
      I do vents when I really, really, really have too
      I use my drum machine right now, but think I have found a use for the K-60.
      I hate roof vents because the risk of getting stuck and the loss of cleaning ability.
      Even pulling a toilet is horrible, going through the closet bend, the santee then the comby on most set ups greatly reduces the cleaning ability.
      Robert
        I go on a roof all the time. Be wary of going into a 2" vent into the main line. Catch into a big root ball and you'll rethink the pulling toilet.
          I almost never go through vents. If there is no cleanout, I pull a toilet.
          The K-60 is the best for roof vents if you have to do it.
            i too go on roofs all the time thanks to the k-60
            if all i have is a 2'' vent, then i might as well do it from a kitchen or laundry c/o. if the stoppage is in a 3''or 4'' main, you really want to access a 3''or larger vent or c/o or toilet.
            most older installations around here were 4'' stacks/ vents through the roof. the newer is typically only 2''. also if plastic, they might use vent 90's that will not allow a real snake through.
            size up the job and make an educated decision.
              I hate going on roofs, and usually only have to do it maybe 5 times a year.
              Here 90% of the work i see have cleanouts, curb traps, or stacks. If non of those apply, then i simply pull a toilet.
              I try to avoid roofs at all cost, to dangerous. I dont care what machine you use.
                If there is no cleanout, I install one. Period! Whether 2", 3",4,irregardless. No fixture pulling, no roof work.
                  If I told every customer that they would just call another plumber,or drain cleaning outfit.
                    Our policy was we would only clean from the roof one time and then if they didn't add a ground level cleanout they would have to call someone else.
                      Yep what he said.
                      I`ll do em but I tell em they need a C/O on the ground as I cant get as good of a clean from the roof or a closet bend. I keep thinking some day everyone will have C/O`s but I get 5 or 6 a month that I have to go up on the roof or pull the W/C.
                        Good lord, someone (no, like 4 or 5) agrees with me about roof vents. They are about my last choice for access.
                          i did a 3'' roof vent yesterday / sunday in the rain.
                          the other guy wanted to run his camera from the roof.
                          a camera doesn't fix a house full of waste with 3 kids.
                          a k-60 on the roof makes a very good impression. that's why i call it the
                          impressionator
                          now they want me to camera the line and install a ground level cleanout.
                          common sence. clear the line, then worry about the future access.
                            rough guess....5-10%.
                              rain..... that's when the snow comes down melted, right?
