Bang for the buck......?
    Re: Bang for the buck......?
    if you're going to do this for a living, move up to a 7500 and a 3800.
    the 380 is more of a handyman unit.
    the 750 is good, but the 7500 has a much better motor, auto feed and stair climbers. along with 25' more capacity.
    now if you want new or used, i have the 750 and 7500 new and used.
    in fact i'll probably only keep 1 drum machine now.
    Originally posted by All Clear Sewer View Post
    Heres my 380 at work
    I noticed no powerfeed.
    I've used 'em with & w/o.
    Personnaly, I thought powerfeeds were too slow,
    took away command of the cable, got in the way, and for the
    most part were completely unneccesary.
      yep
      I cant see any good uses for a power feed on the 380 as it will get in the way
        is that 3/8'' or 1/2'' cable?
        what happened, couldn't get the 7500 in the bathroom
        good catch,
        but 1 day the sharks will beat the fisherman and his trout pole
          But not the mighty electric eel!! Or the k60 !
            Rick it`s 3/8
            The K-7500 would have fit fine but I thought it was a grease and paper clog. ((They had white carpet and the 7500 was muddy from being used outside.)) I was shocked when I pulled it back and saw the root ball.
              Never used a 380. I have the 3800. Catalog says it can use a "front guide hose adapter kit." Anyone know if that means the hose and autofeed for the K40? If so, I think I'll retire the power spin.
                i believe it's a front guide hose in case you're more than a few feet from the drain opening.
                it's not a power feed.
                • #23
                  They do have a auto feed for the 380 as an option, 87337 is the number my manual has in it.
                  I have not seen reference for a front hose adaptor, for the 380 the 380 power feed has no place for a hose to attached to, (one could probly make some type of adaptor)
                  jsut looked on the manual of the 3800 (think it was page 11) (never used the 3800 so I do not know by experience).
                  on the 3800 the power feed or auto feed has a collar that appears it has a place for a hose attachment,
                  http://www.ridgid.com/ASSETS/CFB2C4D...achine_Man.pdf
                  • #24
                    "just looked on the manual of the 3800 (think it was page 11) (never used the 3800 so I do not know by experience).
                    on the 3800 the power feed or auto feed has a collar that appears it has a place for a hose attachment,"
                    Yeah, does look like hose can fit on autofeed. I don't have autofeed for my 3800, but was considering the "hose adapter kit" (62412), if it means it adapts to the k40's guide hose and end of hose autofeed. I can't find any other hose that it would be. Would use for tub and 1 1/2 galv, and WM.
                    Hose alone might be hard without autofeed. What I really want is the hose. Autofeed just to allow me to use a hose.
                    Would like to have something to where I could snake WM without having to move WM. Usually, packing starts leaking, and twice, drain hose started leaking (plastic corrugated).
                    and to be able to retire power spin.
                    • #25
                      I made my own feed hose for the k3800. I'll post a pic in a week(on vacation now) in this thread. I think mine cost 12$ to make.
