K380 autofeeder not working ? Page Title Module
  • K380 autofeeder not working ?
    I have recently started to use a K380 I purchased a year or so ago to replace my K375. My problem is with the auto feeder that came with the unit new. it doesn't seem to work real well. the catalog number of the K380 is 87327. is there is way to adjust the auto feed for the smaller cable that came with the k380? the feeder seems to somewhat feed the cable forward a bit, but it doesn't put it back into the drum, weather it is in a drain or not?
    Sent From The StoolBus
    www.appletondrainandsewer.com
    Appleton WI, 54915
    1-920-284-7471
    Re: K380 autofeeder not working ?
    I cant understand why one would need one on a 380?
      it was the whole kit and for what I paid for it I would expect it to work. I primarily use the feeder to put the cable back into the drum.
      I received a greet deal on a close out model.
      Appleton WI, 54915
      1-920-284-7471
        There is no adjustment that I know of, you just have to make sure you have the lever pushed ALL THE WAY DOWN, if not it doesn't engage. Hopefully someone here knows a way to adjust it to make it work better, because its a pain having to push so hard on the lever every time.
