Flat Sewer Tape
    Re: Flat Sewer Tape
    When I did trenchless I used a camera to make my measurements.
    Yeah, I agree, the post cards witht he historic theme was a good idea, something I work on for sure.
    Robert
      Re: Flat Sewer Tape
      I watched my dad use them all the time as well. When he did plumbing, his toolbox consisted of a hammer, flat head, phillips head screwdrivers, pipe wrench, plunger, chisel, and a flat sewer tape. He would clear lines with them. I still have it. It sits in my office. Thanks dad for getting me hooked
        Re: Flat Sewer Tape
        I've got a friend that still uses a flat tape for all his sewers.
        A guy that I used to work for used flat tapes with wire coat hangers bent and wrapped around the ball to act as hooks. Talk about primitive. He'd charge seventy five dollars a trip. talk about EASY money.
        I don't know why anybody would call him back a second time though.
          Re: Flat Sewer Tape
          i use them for frozen drain lines. i tape the hose right to the end of flat sewer tape with a fine spraying nozzle at end. its good to nip away at the ice. just make sure you have a large enough trash can at c/o opening to catch water before you free up frozen main line. otherwise you have a big mess to pick up. then i just pump the water back into the main line with small pump.
          "a mans only as good as the snake he uses"
            Re: Flat Sewer Tape
            If I know I only need to go 10' or so and I don't have the jetter with me, I do the same type of thing but, I fill a trash can up and use a submersible pump with a garden hose attachment. As long as the water coming back doesn't have too much debris (clogs pump) It goes pretty quick.
            I even keep a clean pump to do the same thing with water lines. I just use a bucket or tote and, an ice maker line (ironic).
              Re: Flat Sewer Tape
              Use my old flat sewer rod with the ball end to clear old brick chimneys with offsets. Start at the bottom and pound it up the chimney and down comes the old bricks. A lot quicker and cleaner than blasting out bricks in the attic. Once you have it out the top turn it around in circles with a big fitsall (cresent wrench) and it cleans the rest of the crap out. Go ahead and pull your new liner without getting all hung up. Wear gloves and safety glasses. Watch out for the falling bricks, damn do they hurt. Great for squirrel nests also.
              WE LIVE IN THE LAND OF THE FREE,
              ONLY BECAUSE OF THE BRAVE
