ridgid k 50
  • ridgid k 50
    As i'm only just starting out on my new venture, i can pickup a Ridgid k 50 for about £ 150 with a 7metre 16mm cable, am i wasting my time with this or do i need to go for something bigger ? thankyou.
    Re: ridgid k 50
    what size lines will you be working on? you would be better off with the K-60 because of it's flexibility. both 5/8 & 7/8 cable.
    good luck with your venture
    steve
      Re: ridgid k 50
      Thanks steve, i'm in britain and was thinking maybe i could use this for toilets, sinks, etc, anyway, JUST bought it off ebay, by the way, i said 16mm cable,, 3/8, ? i meant 6mm, which i see is a lot smaller, have i paid too much?
        Re: ridgid k 50
        First off welcome to the forum
        The K-50 is my favorite drain machine. With a bulb adapter you can run:
        5/16" for 3/4" through 1 1/2"
        3/8" for ! 1/4" through 2"
        Without an adapter you can run:
        5/8" cable for 1 1/4" through 4"
        In the larger sizes (3" & 4") you would not want to use it to clean a root stoppage.
        http://www.ridgid.com/Tools/K50-Drain-Machine
          Re: ridgid k 50
          my K-50 has 5/8 inch x 7.5 feet sectionals. the 50 is a good machine and has a lot of uses. it just isn't robust enough for roots or other hard blockages. iv'e run mine down 4" with no issues. but you will need as larger cable for long runs and larger pipes. i haven't used the "drums" i bought with mine as they aren't efficient for me.
          save your euros and look into the K-60. a lot of folks on the forum use'em and sear by them. it's on my wsh list.
          can't speak to you purchase price as i don't know about used ones. rick and others will chime in and have ALL the scoop on the machine
          steve
            Re: ridgid k 50
            Thanks, your a star (in the uk ) bit cofused on the bulb bit, do you mean o the end/tip?
            Apart from your last sentence, i'm confused relating to what your, x through y means, appreciate your help
            stxrus, thanks for your input,but iv'e been put at ease by the last poster, i think we british cannot get this stuff at usa prices, so, have to go with what we are offered at the right price , ? i think.
              Re: ridgid k 50
              Forgive my attempt at metric but here goes.
              With the 5/8" cable (15mm) you can clean 1 1/4" (32mm) pipe up to and including 4" (101mm) pipe.
              With the 3/8" cable (9MM) you can clean 1 1/4" (32mm) pipe up to and including 2" (50mm) pipe.
              With the 5/16" cable (5mm) you can clean 3/4" (19mm) pipe up to and including 1 1/2" (38mm) pipe.
              The bulb adapter is a plastic bulb which installs on the back of the K-50 to allow you to run the two smaller cables like a drum machine.
                Re: ridgid k 50
                Mark. please have look at this, i know it's a bit rough, only for short drains in the uk inside the home, can you suggest what i need to add to make it work, help my customers ? thanks.http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=003
                  Re: ridgid k 50
                  The machine looks a little warn but worth cleaning up. The canister which has been removed from the K-50 is likely the A-17_ adapter and could use a new cable. I would replace the rubber feet on the legs so you can protect the surface you are working on and you should add a A30 cable kit. I will try to post a picture of a decked out K-50.
                    Re: ridgid k 50
                    ThANKS MARK, AND TO ALL help , been educated, can you tell me a price for the 50 or the 60?
                      Re: ridgid k 50
                      hey Mark whats the link to that set-up.Part #
                      I want to order that total deal.
                        Re: ridgid k 50
                        That is the K-50-8 with a catalog number of 59000
                          Re: ridgid k 50
                          Thanks
                            Re: ridgid k 50
                            all clear, are you serious
                            you're going k-50 instead of k-60
                            even mark knows the k-60 is king
                            nothing wrong with the 50 as i have 4 of them
                            but if i had the choice between a 50 and a 60, well the rest is history
