handheld power augars
  • handheld power augars
    anyone useing a k-39? what about a power or super vee, im thinking about a power vee i have used the super vee a few times and loved it.
    how is it that so many answers are in the instructions
    Re: handheld power augars
    I have the k39 auto feed and love it, has a bit of torque to it but hey it helps!
    I have a general also.
    Seattle Drain Service
      i hae never used or sceen the ridgid
        I also have a k39af but would buy a k40 if I had to do it over again.
          trade you ben.
          proplumb
          the newest design allows the k-39 to rotate in a clockwise direction and still feed in and out. reverse is typically used when you're stuck.
            proplumb
            So does the new K-40. Ridgid listened to me and put the k39 AF on the k40.
            Can't take credit but the timing was mighty suspicous.
              I like the ridgid autospin. cables are cheap and it helps keep the mess controllable.
              Sent From The StoolBus
              www.appletondrainandsewer.com
              Appleton WI, 54915
              1-920-284-7471
                autospin is definitely for the DIYs, not pros. Its junk.
                  spartan 81 is What I Own
                    great machine...very quiet
                      If you guys like the Spartan 81 you really need to demo the K-50 while at the roundup. Where the K-60 is Rick's favorite machine the K-50 is mine. Not only will the K-50 run 5/8" cable but by using the A-17-A and the A-17-B adapter you can also run 5/16" and 3/8" cables. Here is a picture of the K-50 with a A-17-A adapter full of 5/16" cable. Ridgid does not do a great job of showing/explaining/bragging/showing off the versatility of the K-50 on their site.
                        Never liked the 81. It's to easy to throw a loop inside the drum. I even put a wing nut on it to try to keep the cable from throwing a loop. It has it's purpose I guess. The hand drill with the three point chuck is better IMO, some people don't like it because it's heavy but I think it's fine.
                          I have the super vee and it is excellent. General makes one heck of a great top snake.
                          Robert
                            Hey Drain Medic why do you say the auto spin is junk ?
                            I have been using one for 2 years, and only had to replace the cable 3-4 times?
                            it works great in urinals and sinks that you don't think the trap will come off without replacing the plumbing. "Galvanized "
                            Appleton WI, 54915
                            1-920-284-7471
                              do I use it as much as my K3800 no, but it dose work for its purpose?
                              it is a cheaper tool but just like all tools if you abuse it will break.
                              Appleton WI, 54915
                              1-920-284-7471
