nothing to brag about
  • nothing to brag about
    A service call I did monday..... The most time consuming part of the job was there was no sweep to gain access. access was A "T" I'm sure the plumbing inspector give it a thumbs up when installed..... and when you got roots on your sectionals your going to be there a while .
    Never give up on your dreams..
    dreams are what make us forge ahead.
    Re: nothing to brag about
    Impressive,How long did it take? What type cutter head did you use?
    Kenneth Collier
    Maintenance and Sewer
    P.O. Box 9441
    Jackson, MS 39206
    (601) 613-2678 (Cell)
    drainman881999@yahoo.com
      Was there about 2 hours,,, not really impressive by my standards,,, a lot of bigger one's that are posted here.... for now.... didn't even have to brake out my 100' tape...
      Take care buddy,
      Scott
        Take care buddy,
        Scott
        Edit...................... was a 3.5 inch spiral cutter
          Good Pull.
          How long? 12`?
          Where did they come from, I see no trees in those pictures?
            Originally posted by All Clear Sewer View Post
            Good Pull.
            How long? 12`?
            I tried to use trick photography,,, not very long...... trees all around....
            have to get use of new camera,,, the pain the the butt was trying to get the eels out from a "T" c/o with the wrap.... downstream....
            Scott
              Nice catch, how far out?
                Nice drill. Looks just like my 'Edith'.
                I have a longer shaft on mine though 1' (jealous?) , I,ve thought of cutting it shorter but I like the idea of the cable being further away from me just in case. Have you used a drill with a longer shaft but found you prefer it shorter? I'm thinking shorter may offer more control.
                  I'd get that stuffed and mounted.
                    You name your equipment too !,.... I guess I'm not the only one.... I name mine Bunny... they just keep going.... going.....
                    I make my mine by cutting off and end of my old Eels,,, grinding off the outer cable wound,,, and punching out the pin of the inner cable..... insert a 1/2" bolt and have it tack weld..... thats good old Yankee ingenuity
                      about 10' in..... ran the Eel's to the next c/o about 50' away...
                      Back of an old strip mall.... could not go back stream because the second c/o had a sweep.
                        Aren't you guy worried about getting the cable stuck with that thing? I mean it seems like it would be hard to retrieve a cable(if it was stuck) with a hand machine instead of a drain machine firmly planted on the ground.
                        Does seem like a great idea though.
                          I only go about 130lbs but I think I can hold my ground better than a drain machine
                            And what do you mean by "that thing"?? Her Name is EDITH
                              Does EDITH have variable speed as she looks like an accident waiting to happen, and thats a women for you.
                              Tony
