Left wind cable
  • Left wind cable
    What's it for? Won't it unwind when running in forward?
    Re: Left wind cable
    They are for when you are tired of running your machine in forward
      Re: Left wind cable
      As it's now running the other way,reverse,to work, could the life of your machine not be extended?
      e.g., your car spends most of it's life in forward gears, getting worn, the reverse hardly sees any wear, now, it's time to get your money's worth
        Re: Left wind cable
        Your my kind of helper, Want a job
          Re: Left wind cable
          marco products are left hand wind
            Re: Left wind cable
            My marco is NOT left hand wind
              Re: Left wind cable
              Just figured out, Gorlitz use the left wind cable. Does this mean if they run a right wind cable, it needs to run in reverse?
                Re: Left wind cable
                the marco uses a right hand wind that expands against the locking device or chuck to eliminate slippage.
                my buddy uses marco and claims that they get around the stuck cables better than the others?
