Galvz.1.5 trap with c/o plug
  • Galvz.1.5 trap with c/o plug
    How do you all unclog these?This one had not been cleaned in over 20 yrs.The kit. sink line was the same way,Full of Hard Black Muck the length of the runs and had been draining very slow over several years according to the owner. I was trying to post a picture of this trap, but it's either the camera's fault or operator error. Most likely operator. LOL.
    Kenneth Collier
    Maintenance and Sewer
    P.O. Box 9441
    Jackson, MS 39206
    (601) 613-2678 (Cell)
    drainman881999@yahoo.com
    Re: Galvz.1.5 trap with c/o plug
    If it`s what I think it is I`d just use my top snake.
      Thanks All Clear, what size cable?5/16? I have always used a k-50 with 5/8" cable and have been thinking of buying a k-39 since it seems to be highly rated.On a side note_are you based in Kansas city? If so do you know Jeff at Key Equipment?I purchased an old Myers jetter from him in late 1999,they all seemed to be good people.
      Kenneth Collier
      P.O. Box 9441
      Jackson, MS 39206
        Yep 5/16
        I bend the end so it cleans better
        Now I`m in Hutchinson Ks about 50 miles north west of wichita Ks
          Thanks. ALL CLEAR. My cousin lives in Wichita on English Street. Last time I was there 2 years ago, I enjoyed that city. I call it God's country, but I like everywhere I go so we all live in God's country! I always enjoy reading yours.plumber Rick's, and West Coast plumber postings.
          Kenneth Collier
          P.O. Box 9441
          Jackson, MS 39206
            If at all possible i would cut out the trap and use a no hub to plastic and re pipe it in PVC. Try to rod it while running warm water slowly down with it if you can. Once it is open fill up the sink bowls to the top to give it a good rinsing.
            5/16" is a good call too!
            Last edited by jrsaltz; 03-28-2008, 07:45 PM. Reason: Forgot to add the last comment.
            www.firstresponsedrain.com
              In these situations I normally use my K-60 with 5/16 cables if I can access the pipes directly. Quite often I use my K-39 directly through plug holes ( if the trap style allows ) this is handy as pipe work doesnt have to be disassembled and water can be slowly turned on to help assist with blockage removal whilst drilling.
              Cheers Gary
                I put my special tip bend on it, and run a 1/4" cable from my general super vee, I go from the top strainer down the tubular.
                I do it on lavs also.
                now, if I get back alot of muck, then I will drop the trap and run a 3/8 inner core, with a good bend, spartan machine of course.
                drum need I mention.
                Robert
                  I put my special tip bend on it, and run a 5/16" cable from my Ridgid K-50. I go from the top strainer down the tubular.
                  now, if I get back alot of muck, then I will drop the trap and run a 5/8" sectional cable from the same Ridgid K-50 machine of course.
                  drum and sectional best of both worlds need I mention.
                  mark
                    mark
                    whats a special tip?
                    Mike
                    www.plumbinginclarkcounty.com
                      Sorry I was teasing Robert and using his post with my machine. However, what Robert was referring to when he said "my special tip bend" is a slight bend he puts on the end of his cable to help clean the walls of the drain and negotiate changes of direction..
                        i logged and and read special tip? i thought i was on a different type of forum
                        Mike
                          wrong forum.
