would this pump be good for a DIY jetter ?
  • would this pump be good for a DIY jetter ?
    It is a Dayton pump
    4000 PSI max 4.8 gallon a minute
    Dayton High Pressure Pump 3XU52
    Sent From The StoolBus
    www.appletondrainandsewer.com
    Appleton WI, 54915
    1-920-284-7471
    Re: would this pump be good for a DIY jetter ?
    too much money from graingers.
    look up water cannon and look at the general/ interpump 2021
    5.6 gpm at 3500#
    should be around $400.
    but you still need a 16-18 hp. engine and the rest of the assy. such as a gear box/ speed reducer, or pulley system and an unloader.
    might be less expensive to price out a complete unit with those specs and add the pulsation valve to the center port.
      I have the pump and engine.
      the pulleys are easy.
      dayton states a 12 horse is what it takes?
      Appleton WI, 54915
      1-920-284-7471
        you need to read the fine print.
        the 12 horsepower is based on an electric motor, running at 1750 rpm at the pump.
        i'm going to say you need a min. of 18 h.p on a gas engine. to hit those specs.
        do the math before you get disappointed. what h.p is your engine?
          older kohler 14 hp
          Appleton WI, 54915
          1-920-284-7471
            you'll probably be safe at 3000# if the engine is up to speed.
            1750 is the max pump speed and that pump requires a 24mm. pulley shaft.
            you'll probably be better at 3200 rpm max at your engine and the pump will still turn at 1600 which will still produce 4 gpm. at 3000#.
            still a good system for up to 4'' pipe.
            my 18 h.p portable produces 5.6 gpm at 3500 psi max. i keep it at 3000# to give it a rest.
            gpm is more valuable than psi.
